M: Raadiovastuvõtja Degen DE1103
Kompaktne AM/SSB/FM vastuvõtja. Ideaalne lahendus matkale, kalale või öökapi peale.
Sellega kuuleb SSB raadioamatööride jaamu, 27 mhz Rekkameeste juttu, Kaugemad lühilaine jaamu ja palju muud...
Väga tundlik FM vastuvõtja. Välisantenniga kuulen Valgas Tallinna ja Soome jaamu... Tavalise teleskoobiga tulevad Tartu jaamad vabalt.
FM / shortwave / medium wave / long wave .
FM frequency range :76.0-108 .0 MHz (covering school band), step length 25K.
AM (with shortwave. Mediumwave. Longwave) frequency range :100-29999KHz, step 1K.
AM-band high-frequency (55.845MHz) second frequency, high sensitivity, high resistance to interference.
Shuttle / auto search / memory / direct input four kinds of tuning.
268 Radio permanent storage (with implicit sub-area convenience store area).
Permanent preservation of memory information (except the clock).
64 electronic volume control.
Direct digital input and Adjust the shuttle.
Large LCD screen, LCD dual-frequency analog and digital instruction pointer mode.
Compatible with NiMH / NiCd batteries, rechargeable countdown query.
Single sideband (SSB) receiver.
AM in the bandwidth / narrow choices.
Panel full orange backlighting, three backlight mode.
AM signal strength indicator.
FM mono / stereo selection.
News / music two kinds of sound choices.
Sleep time 1 ~ 99 minute.
Clock display.
Electronic switch key lock function.
Key operation error.
Battery ladder instructions to view the current power grid, low battery auto shutdown.
Long rod antenna to improve FM and shortwave reception.
Large-diameter speaker (D77mm), sound quality and beautiful.
Set an external antenna jack, use an external antenna to improve signal reception.
Use 4 AA batteries. (Pole komplektis)
Venekeelne ülevaade:
http://www.radioscanner.ru/info/article10/
Mu tehtud video, mida on kuulda Valgas FM jaamadest.
Antenniks dipol akna taga. (Kahjuks heli vaikne)
http://youtu.be/4Y9BGfEMNd8
Youtubest leitud video, Radio piraadid 2920 khz SSB
http://youtu.be/gKdb1crXZBI
Uus pakendis
Hind 70.- eur
Saadan Post24 või Smart.
PM või 50 seitse kuus 179
