Lada 2101 V6
Lada 2101 V6
Pöhö-Andrei
Autod: Lada 2101 V6
Postitus Postitas Pöhö-Andrei »
More carburators, more power. :lol
[Muudetud: 23-5-2009 Pöhö-Andrei]Pilt
Ainoana suomessa Lada 2101 V6
u
uzzac
Autod: Volvo S40
Postitus Postitas uzzac »
nice
Pöhö-Andrei
Autod: Lada 2101 V6
Thank you...
Flywheel after slimming diet...Pilt
Pöhö-Andrei
Autod: Lada 2101 V6
Made by myself.Pilt
what type of crankshaf are you using to get the pistons so far out?
21011 block or 84mm crank?
show the pics of the head where this piston will fit :)
Pöhö-Andrei
Autod: Lada 2101 V6
Block is 21213 1.7L.
Stoke :D
Now it looks like this.. Piston +0.2mm over deck.Pilt
Pöhö-Andrei
Autod: Lada 2101 V6
PTFE-plug in pistonpin.Pilt
i see you are using 21083 pistons with big dish in the center - how are you planning to get the CR up again.
you shaved 1,8mm from the engine block?
how much are you planning to shave off from the cylinderhead?
now the CR looks like something about 9,6 with standard combustion chamber...
Pöhö-Andrei
Autod: Lada 2101 V6
Algselt postitas: olaaf
Yes, these pistons are from 2108 engine. In 2110 engine are same pistons but with lock-ring for pin. Now i must use PTFE-plug for locking pistonpin.
I measured this dish size from 2108 and 21213 pistons and results are very interesting. 2108 dish looks very big, but it is only 1cc bigger than dish in 21213 piston. 2108 13cc, 21213 12cc. But now i get much bigger pockets for valves, and i can use much bigger valvelift.
Now with bigger stroke and after piston modification that dish is only 7cc and that will give big help for CR. Sylinderhead lost about 2mm and CR was 11.6:1 so i get good chance to make little bit modification to chamber and get some more flow space for valves.
Now CR is 11.3:1. I think it is enough.
[Muudetud: 26-5-2009 Pöhö-Andrei]
Pöhö-Andrei
Autod: Lada 2101 V6
A little bit more...Pilt
Ekke-Taavi
Autod: Saab 96L; Zaz 965; Seat Leon
Postitus Postitas Ekke-Taavi »
power of dreams :D
prõnn prõnn prõnn...
Algselt postitas: Pöhö-Andrei
My suggestion would be to trim the edges and corners of combustion chamber.
Any sharp corner and edge will increase the possibilty of detonation in combustion chamber
Pöhö-Andrei
Autod: Lada 2101 V6
That foto was taken before polish and finishing.
Now chamber is smooth and without sharp edges. :D
[Muudetud: 27-5-2009 Pöhö-Andrei]
Pöhö-Andrei
Autod: Lada 2101 V6
Rubberpads.Pilt
That's good to hear :)
What are the dimensions of the exhaust header ?
I mean the runner pipe diameter and the end of the header.
And how thick is the pipe wall?
Pöhö-Andrei
Autod: Lada 2101 V6
Algselt postitas: PuZuP
I knew that possibilty of detonation with sharpe edges, so i gave my best shot to eliminated it.
I dont remember runner pipes diameter but maybe they are 38mm and end of the header is 2" pipe (50,8mm). Thicknes of the pipes are 1.5mm.
I will measure these details and give more information during weekend.
http://www.martelius.com/
Also in english.
Pöhö-Andrei
Autod: Lada 2101 V6
More engine pictures coming soon.
Now little bit brake pictures.Pilt
Pöhö-Andrei
Autod: Lada 2101 V6
Rear-axel.
Only brakes are missing.Pilt
Ervn
Autod: Ford Sierra
Postitus Postitas Ervn »
Very Nice! :)
Pöhö-Andrei
Autod: Lada 2101 V6
Detail of spareparts.Pilt
