Leidsin Defa Alarmile juhendit kuidas pulte programmerida
Kui kedagi huvitab:
Coding new DEFA Remote Controls --- For more information, contact an authorised DEFA dealer
A. One short press on button B to turn off the alarm and immobilizer (if fitted). Emergency
disconnection can also be used.
B. Turn the ignition on and off 5 times in succession. The LED flashes rapidly when the
ignition is turned off the fifth time.
C. When you turn the ignition ON again, the LED should flash. Let the LED flash just as
many times as the first digit in your PIN code, and turn off the ignition (the LED stops
flashing).
D. Turn the ignition ON again and repeat the procedure until you have been through all of
the digits in the PIN code.
E. The LED flashes rapidly when the ignition is turned off after the correct PIN code has
been entered. If you make a mistake you can start from point C with the first digit in
your PIN code.
F. Turn the ignition on again, and press buttons A and B at the same time on the remote
control to be coded (one remote control at a time). Hold the buttons in until you have
received both light and sound receipt.
G. Turn off the ignition when all of the remote controls have been coded.
NOTE ! When you code the remote controls all of the old settings are deleted. You can code a
maximum of 4 remote controls.
